Clutch suggestions...moderate mods soon, twins later...
Old 11-13-2006, 07:59 PM
502502's Avatar
Originally Posted by Boondock
Ok if you say so hotmopr.
His name is Tomeygun on TDR. Here is a couple of quotes
I have the same clutch - MU13.125- OFE...
I know its crazy, buts it holds 600hp on the street... Only slipped when asked to hold a 4wd - 2nd gear launch from 2500 rpms...
I give this clutch a big thumbs up for quality, Althought I would go with the higher plate load thats now available...
Here is what is done to his rig 2003 3500 QUAD CAB,SO/5-SPD, TST/EZ, SLEDPULLER 66, SBC MU13-1.25 CON OFE, 5" STACKS , GOT FLUX ?!, DPP Fuel pump, CP3 modified by FLOOR-IT Diesel! -- STL, MO DYNO Day Video!
DYNO Runs (W/ Video) <-- (604.8hp!)
Also numerous others over 500hp with the OFE holding fine. Consider its rated at 450/1000 that is awesome.
Kurtis
BTW - CON OFE Still holding
But not very good when side-stepping for a burnout
Old 11-13-2006, 09:04 PM
Forrest Nearing's Avatar
the OFE in my truck held up to DDP4's, 215 pump, less than zero plate, cut up AFC, and 35/400 twins!!! Peter seriously underrates his clutches
Old 11-14-2006, 08:24 AM
gunracer1's Avatar
my fe would not hold at 400 rwhp if i tried to speed shift. from 3rd to 4th at 4k or so it slipped every time. and would not grab till i let off. ot held on the dyno fine and i even sled pulled with it.
Old 11-14-2006, 08:34 AM
nates90's Avatar
I would go with the mu 13-1.25 con fe.......thats what i want....DD is just too pricy....but....I dont know where your heading with your horse and torque.
dodgediesel
ABDTR #5
10-18-2011 09:22 PM
dodgediesel
ABDTR #5
496
10-16-2011 04:33 PM
abchoppers
10-03-2010 05:34 PM
dblack98
08-20-2009 12:32 PM
Mcmopar
07-09-2004 03:48 PM
Quick Reply: Clutch suggestions...moderate mods soon, twins later...
