Clutch engages while pedal down
Old 08-17-2007 | 01:17 AM
dieseldel's Avatar
Cool Clutch engages while pedal down
Oh, boy. I was sitting at stop light, in 1st gear, clutch pedal all the way to the floor. All at once clutch engaged all by itself, and I had a heck of a time keeping from hitting the guy in front of me. I finally got it out of gear. Then it didn't want to go into any gear til I pumped the clutch pedal. Now all acts normal. I guess this is a hydraulic clutch? If so, maybe leaky master/slave cylinder?
This makes me nervous. Are the master and slave in one unit, or are they separate?
Old 08-17-2007 | 09:37 AM
infidel's Avatar
Sounds like your throwout bearing is about to fail and is seizing up.
Old 08-17-2007 | 09:44 AM
jp8819's Avatar
Mine started doing same except it wouldn't go in gear sometimes and then pushed pedal to floor and wouldnt stop one day until i pumped it a few times. My master cylinder is wet like its leaking under the dash and talked to a few guys that said that is the issue and if you dont replace it can blow out and cause oil to leak in floor. Im starting there though and order south bend upgraded hyd because it was cheaper than factory and according to south bend will work with factory clutch no problems.
Old 08-17-2007 | 10:51 AM
1stGen545's Avatar
If it's not low on fluid it's the master. There is only one seal in the slave and if it goes it will leak to the outside. The inturnal seal on the master can leak fluid by on the inside and not to the outside. If you are not low on fluid then its your master. You can get them separate. The SB kit is already put together and is already got fluid in it and ready to go.
Old 08-18-2007 | 02:10 AM
dieseldel's Avatar
Thanks guys, that's good info, helps a lot.
I'll check the throwout bearing too, but it appears its a leaky master cyl.
I may just replace both master and slave while I'm at it.
Thanks again,
Del
Old 08-20-2007 | 09:26 AM
DZLPWR's Avatar
Yeah get the whole unit, its already full of fluid which means no bleeding (big PITA) Took me about 30min to replace the whole unit.
dsl dave
16
07-11-2009 02:44 PM
CTD NUT
08-02-2008 09:14 AM
MOCOP
18
07-12-2008 10:02 PM
99DodgeGuy
01-10-2008 08:00 PM
DJ
09-14-2004 02:40 PM
Quick Reply: Clutch engages while pedal down
