Clevite p series vs h series.
Old 01-23-2020 | 11:08 AM
GageMarzigliano's Avatar
Originally Posted by AlpineRAM
I'd talk to the machine shop after they measured the crank. They usually have experience on what works fine for the measurements they took.
If you buy bearings according to a list of measurements you will need to verify with plastigage after installation, and if not within specs the fun and blame games begin.
i was told the crank is perfect, so standard it is! So I’ll plastigage and hope for the best!
Old 01-24-2020 | 02:02 AM
AlpineRAM's Avatar
Yep, but with the crank in spec I never had problems with Cummins bearings. They were all in spec according to my plastigage measuring. (But I still do it for every engine.. )
Old 01-25-2020 | 02:54 PM
off topic (hope that’s alright) but what’s a good gasket tack to use? Permatex hi tack 80062 is what my local has.
Old 01-26-2020 | 02:53 AM
AlpineRAM's Avatar
No tack on the head gasket for me.. also none on the other gaskets. Either a gasket does it's job, or a sealant bead does the job.
Also- crankshaft seals on the Cummins B-series.. Install dry, else they will not seal.
nothingbutdarts (01-27-2020)
Old 01-28-2020 | 04:49 PM
sounds good, thanks for the tip!
dodgetrucker75
05-29-2010 06:18 AM
djcheez
14
11-24-2009 06:44 AM
haloman
06-25-2007 09:23 AM
Jeff in TD
09-05-2006 03:50 PM
1ST CUMNZ
03-05-2004 05:41 PM
Quick Reply: Clevite p series vs h series.
