Choices Injectors/Housing or Turbo
Old 06-23-2008 | 11:42 AM
kiohio1985's Avatar
I am slowly getting the truck around to running like it should.
Now I'd like to make it run better and get my EGT's down a little bit.
I am going to get my 3gsk and install it before anything else....
After that I have a choice to make on which way I'd like to go.
My Budget is around $1500 give or take a couple hundred.
1. An HTT 62/14 turbo and nothing else for a while.
This would definitely cool the EGT's
2. A 14cm housing for my stock HX35, or a Dodgezilla type turbo and a set of DDP2 injectors.
This would cool me down a little but also possibly boost my mileage which is always a good thing.
I'm leaning toward the injectors/Dodgezilla mainly because the stockers
(turbo and injectors) have 215K on them so I know they need attention before too long.
The turbo has been spun way too 40 psi a few too many times I'm sure before I got the truck.
KO
I'm open to suggestions.
Old 06-23-2008 | 12:00 PM
Gary Emerald's Avatar
buy a used S300 for $900-1100 and put the rest towards injectors. even if it means saving for a little longer.
Old 06-23-2008 | 03:59 PM
kiohio1985's Avatar
What size do I need........
Don't they make alot of different S300's?
Different variations and such.
KO
Old 06-23-2008 | 06:34 PM
yes, I would do a 62mm compressor, 65mm turbine, and a14cm housing, IE, HTB2, II Phat shaft 62, etc.
nickg
15
07-10-2009 11:09 AM
dieselram_04
06-18-2007 06:08 PM
88bird
15
02-27-2007 12:11 AM
lil jim
04-08-2005 04:40 PM
More Power
05-05-2004 02:15 AM
