Can injectors be installed in a parking lot ?
I'm looking at a 1991 dodge D350 which has a bad injector and dealer is sellling as is.
Could I install a new injector in the parking lot with the right tools ?
Thanks guys !
Thanks guys !
I have done the injectors without pulling the lines from the pump and its tricky as they are all tied together with special line clamps. You probably will have to pull the lines to the front three cylinders all at once to get the lines out of the way enough to pull the injector out. If the lines are not broken from the pump, no priming required.
Beware, bending the lines even just a little bit can crack, weaken or make them very difficult to line back up.
You actually will save yourself much work in the long run by totally removing the lines by disconnecting them at both ends.
That includes the small return line.
I swapped out injectors on a members truck in a parking lot on a dyno day. Nothing says fun like an engine fresh off the dyno. A small cup or tray is nice for the small banjo bolts and horseshoe washers for the return line, easy to drop and hard to find.
07_Ram
03-19-2012 02:23 PM
fanofthewolf
02-14-2004 12:50 AM
