bucking: recall issue or fueling?
my truck bucks under light acceleration. i thought that i read somewhere here that there was a recall on a linkage problem with 94's and 95's. or can this be a fueling problem from low pressure or leaks.
if its the recall, will dodge still replace it (for free)?
if its fueling, what is usually the culprit? and how do i diagnose?
thanks
thanks
Usually bucking is caused by a broken or disconnected throttle return spring. There are two of them, one inside the other. A hardware store spring will work.
If your truck hasn't had the linkage/cable recall it should.
Check recalls here, you will need your VIN http://www.dodge.com/webselfservice/...m('R')
i checked with my vin and no recalls performed. what is exactely the recall and the symtoms ? will dodge do it for free still? whats the language i should use when i go cause i know they are going to try to talk me out of it or do it then charge me for something else.
and also is there a diagram/pic of where those return springs are located? thanks!
Look a your throttle cable - it should be obvious.
http://dodgeram.info/tsb/1997/18-29-97.htm
heres another that may apply to you: http://dodgeram.info/tsb/recalls/970.htm
Exactly how could I have changed the years of the recall???
The first one is a Technical Service Bulletin - and is not a recall. Its DC stating there may be a problem with some trucks and will do a repair to make their customers happy. A Recall generally only affects systems on the truck that are involved with personal/public safety.
And no - these may not apply to you - its up to you to determine if it applies to YOUR truck. Posting for info only.
Idaho Guy
09-20-2009 10:02 AM
stacked07
03-10-2008 06:41 PM
