Brown Smoke = Bad?
Brown Smoke = Bad?
Usually when I stomp on the pedal above 40mph I get tons of acceleration and coal black smoke - I don't do this often, just often enough to know I can, but yesterday when I did it I happened to look in the rear mirror and I noticed the smoke was more of a brown color now. Still have plenty of acceleration but I was wondering what has changed. I sometimes use a Stanadyne additive in the winter but not using anything right now. Bad fuel? Bad injector? Timing changed? My imagination? I've been fueling up at the same place several months now and my only thought is that maybe they've switched over to winter blend and it's something in the fuel. Should I worry?
On my old powerchoke when I ran dyed fuel in it it would put out more smoke and make it a lighter color almost a grey so maybe its something in the fuel like the additives for winter blend
I'm guessing winter fuels b/c here @ 4,000 ft with some cold winters the fuels get pretty crappy for quality, I use schaffers fuel additive RELIGIOUSLY #1 reason is my performance shop uses it in everything (i have schaffers atf in my tranny and transfer case)
#2 the fuel additive in my 1st gen gave me 4mpg by itself!! For the first tank I do a double dose when the first winter hits to make sure everything is lubed and clean. After than its 2 oz. per 9 gallons of diesel. Find a shop and just try it, if anything it might help your L pump by lubing it.
JMO
JMO
HighTen
03-05-2005 11:10 PM
bryanburns
11-01-2004 07:26 PM
Slice
11-24-2003 08:45 AM
