Broken wastegate?
Old 08-21-2006 | 06:42 PM
TxDiesel007's Avatar
Broken wastegate?
Guys,
what is the easiest way to tell if you have a broken or stuck wastegate? What im experiencing is simple.
I had my wastegate blocked and i noticed that my boost was gettin to be about 40 psi max, and that my acceleration was super slow and sluggish. Taking off on a test drive after retightening my g springs, i noticed that the truck should be faster. I decided to plug the wastegate back in, and now i see more smoke than before on all levels and my boost is about 36-38 psi at max now, but with more smoke levels, than the 40 i had before.
Now last i knew my gate was gated (before i blocked it off initially) at 32 psi, and now i can get it as high as what i stated above,
So did i manage to destroy my gate?
Thanks guys
Rick
Old 08-21-2006 | 06:51 PM
TRCM's Avatar
Sounds more like a boost leak to me.
I test drove a new 05, and it wouldn't get out of it's own way. Come to find out one of the boots was not on correctly.
Old 08-21-2006 | 07:25 PM
infidel's Avatar
I always check the gate with compressed air, 40 psi max or you'll blow out the diaphragm. Never seen a gate stick in any position beside totally closed, the spring is very strong.
Old 08-22-2006 | 06:54 AM
TNfarmboy's Avatar
My 98 24v was acting the sam way, found the WG diaphragm leaking, plugged the line but no joy....overboost and ran like a puppy. I just put a manual spring on it last night, which by no means is perfect, but it made a BIG difference.
NoSparkplugs
04-30-2008 11:27 PM
Rpainter
21
03-08-2008 02:36 PM
sallyman1
02-10-2008 06:17 PM
ataboy9026
02-22-2006 05:09 AM
MoparRiggan
10-13-2005 11:54 AM
Quick Reply: Broken wastegate?
