Brake Rotor / Bearing QA
Old 08-28-2004 | 02:43 PM
  #31
nevrenufhp's Avatar
So back to the hub assy: What if you dont remove the axle shaft nut and take the axle shaft out with the hub? I could see how it may be a pain, but as to not open up the bearings. Just not wanting too many extra surprises when I do my rotors.
Old 08-28-2004 | 05:06 PM
  #32
infidel's Avatar
You can't replace the rotors without removing the the unit bearing. Even if you could trying to reinsert the axle with the weight of the rotor on it you'd likely tear up the axle seal.
Don't worry, seperating the bearing is the exception, most slip right off without problem. Biggest problems are in the areas that salt the winter roads, that leaves you out.
Old 08-29-2004 | 05:00 AM
  #33
7mmrum's Avatar
nevrenufhp:
Mine were heavily rusted on their, and from searching this forum in great detail before I started this project, most came off with out any probelms.. I think mine was at the beach a lot before I purchased it.
Old 08-29-2004 | 09:37 AM
  #34
nevrenufhp's Avatar
My other reason for trying another way was I havent found the hub socket yet , but I think I know where I can borrow one.
Old 09-01-2004 | 12:36 AM
  #35
Sidewinder's Avatar
Just to update the leaking axle after the bearing change. As I thought you guys know your stuff. A week later the leak SEEMS to have stopped. Either what leaked past the seal is gone or the seal has magically repaired itself. I hope it is fixed. When I get some time I will clean the area with some degreaser and check again.
Old 09-01-2004 | 06:31 AM
  #36
infidel's Avatar
Sidewinder, I'm sure your seal has "healed". I've had a pair of seals in my glove box for 5 years and over 100k after the last time I pulled my axle.
Old 09-08-2004 | 12:09 PM
  #37
ta3834bbl's Avatar
For clarification, why can't you change the rotors without pulling the bearings?
I did my brakes yesterday and the rotors slid off the studs when I pulled the calipers. Must be a difference in years I guess.
kawi600
32
10-17-2006 08:12 AM
CAMS
08-22-2006 12:48 AM
MR. GADGET
07-18-2006 11:38 AM
Dave88LX
11-06-2005 12:19 AM
Caincando1
10-12-2003 02:25 PM
Quick Reply: Brake Rotor / Bearing QA
