brake fade
Old 04-04-2004 | 07:50 PM
Jambbii's Avatar
Angry brake fade
I am running 38s on my rig and lately I have been following idiots and had to use my brakes real hard and they are fading out. Is there any solution to this?
Thanks
Old 04-04-2004 | 09:08 PM
MnTom's Avatar
Slow down and back off??? Try going to your local auto parts store and see if there is someone who is knowledgeable enough to advise you as to what might be your best option for fade resistant pads and shoes.
Tom
Old 04-04-2004 | 10:11 PM
Jambbii's Avatar
I wish I could slow down and back off but people dont understand that it takes me longer to stop and decide to cut infront of me, its going to be a suprise when my bumper goes through someones back window I just wasn't sure if these trucks had problems. I will check on the pads.
Old 04-05-2004 | 01:01 PM
infidel's Avatar
Your '95 has vacuum assisted brakes, you could have a leak. Most common place for a leak is at the cruise control actuator under the driver's side battery.
Old 04-05-2004 | 02:35 PM
Jambbii's Avatar
I am almost positive there is no leak , but I will double check , I didn't even think of that possibility .
Thanks
Old 04-05-2004 | 05:42 PM
Crimedog's Avatar
Do you have any kind of brake upgrades? A couple of people I know switched to slotted & cross drilled rotors and ceramic brake pads. They said it was a night and day difference, a lot more stopping power. Correct me if I am wrong, but brake fade is because the brakes are getting so hot, and with those 38's, you're creating plenty of heat! The new rotors will run a lot cooler. In the rear, you can swap in new cylinders, they are from an older Chevy truck, but they will put a lot more power to the back brakes. Do a search for the part # on them. If the funds are available, you could get a rear disc kit from Stainless steel brakes corp. that should help you slow down!
Old 04-05-2004 | 06:38 PM
pappyman's Avatar
Be sure your rear brakes are adjusted too.....some times the self adjusters dont work
Old 04-05-2004 | 07:25 PM
Jambbii's Avatar
No brake upgrades, kinda out of the question right now because they are usually pretty expensive. I would like to check into the crossdrilled rotors though. Any more info on those? I'll check my adjusters too.
Thanks
Old 04-05-2004 | 07:43 PM
Crimedog's Avatar
You can get a set of slotted rotors on ebay for 160 bucks. Ceramic pads will be another 50 bucks. I am hopefully going to start working at an auto parts store (Bumper to Bumper) in the next week or so, so I am going to do a full brake job then. I figure I should get out of there with top-notch rotors and pads for 110-120 bucks.
Old 04-05-2004 | 08:04 PM
MnTom's Avatar
Hey Matt, You gonna give us discounts???
Old 04-05-2004 | 08:42 PM
DF5152's Avatar
i would stay away from the drilled rotors and just use the slotted ones. now the pads are a whole nother story have done quite alot of experimenting with different brake stuff including SSBC and EGR Brakes. I like the EGR stuff but that doesnt mean you cant shop around and get a better price on similar stuff. Oh by the way brake fade is cause by your brake fluid boiling in the calipers. When it boils it turns to gas which can be compressed liquids can not. If your fluid has been in there for a while just a flush and refill may help as brake fluid absorbes moisture over time its boiling point drops. so it will fade easier. any other questions send me a PM or E-Mail. dont want to bash anyones pads on here.
Dan
Old 04-05-2004 | 09:57 PM
MnTom's Avatar
You are right Dan, I never thought about the fluid boiling issue. I would strongly recommend you flush the brake system to get new fluid in there.
Tom
Old 04-05-2004 | 10:09 PM
Jambbii's Avatar
I guess a little brake bleed will be first on the list.
Thanks for the replies!
Old 04-05-2004 | 10:19 PM
Crimedog's Avatar
Excellent point, Dan! Go to Geno's Garage and get a couple of bottles of their new DOT 5.1 It has a higher boiling point, and better fluid characteristics. It costs 20 bucks to replace with the new stuff. It also mixes fine with DOT 3 and DOT 4.
96dodge2500
26
11-19-2012 04:35 PM
big jimmy
03-07-2012 12:42 PM
mattzram
02-02-2008 05:59 AM
Herrin811
04-21-2006 06:05 PM
Jambbii
12-30-2003 04:17 PM
Quick Reply: brake fade
