boost gauge for fuel pressure
Old 06-25-2006 | 08:42 AM
turbo6justin's Avatar
I have a grainger generic fuel pressure gauge right now and would like to get an Autometer gauge to match the rest. Problem is autometer does not offer a 0-60 gauge in their Phantom line. I am not real fond of the resolution on the 0-100 psi gauge so I am wondering if I could run a 0-60 psi boost gauge for the fuel pressure. Autometer will not say it will work but I am all but convinced all their pressure gauges are the same with just a different label on the face.
Any opinions?
Old 06-25-2006 | 09:08 AM
ratsun's Avatar
Yes it will work
I use a 0-60 Blower pressure gauge by autometer and no problems but I suggest getting a mechanical liquid filled one to help dampen the pulses from the IP.
Old 06-25-2006 | 09:26 AM
My fuel pressure gauge says "water". Pressure is pressure, the gauge doesn't care. Take a look at http://surpluscenter.com/sort.asp?UI...s&keyword=NFGA
I got my gauge there for $9 and it matches the Z-series gauges perfectly.
Old 06-25-2006 | 09:42 AM
That's what I thought. My exact thoughts were pressure is pressure. My only concern was that the diesel may be 'slightly' more corrosive to the gauge. I do have a needle valve that does a pretty good job at controlling the pulses so I am not worried about the liquid filled part too much. My $6 grainger gauge is liquid filled and does a good job but it is not a lighted gauge and doesn't match very well. I guess I am just getting picky. The doors may rust off but I would like my gauges to match and be readable at night. Kind of funny if you ask me.
Old 06-25-2006 | 11:13 AM
If you have a 12 valve a 0-60 psi gauge would be the best option. Mine idles at about 30. If it is a 24 valve a 0-30 should suffice. If you run it in the cab there is a potential for fuel to leak in the cab. On my drag race cars I always run them outside but in this application I am comfortable running a direct line into the cab. I refuse to use an electrical gauge since I just don't trust them. The way mine is set up if there ever was a leak I would notice it pretty quick because of the smell and all I have to do is close the needle valve and there is no more fuel flow. Also, diesel is not quite as volitile as race gas. I have it set up now through a crappy little nylon line and it has been fine for some time but I just ordered the braded steel line from Summit as I see this as cheap insurance.
Old 06-25-2006 | 11:14 AM
infidel's Avatar
Bill, you will need at least a 40 psi gauge or it will be pegged much of the time. My normal cruising fuel pressure is 33 psi.
60 psi is the best choice because it will read straight up at normal specs.
I also used a $6 Grainger gauge for several years but upgraded to a $9 Autometer from Surplus Center that actually says fuel pressure on it. If you are patent one labeled correctly will come around but as was said all others are compatible with diesel.
Stude4x4
03-11-2012 09:00 AM
dodgeguy71
17
01-19-2012 12:52 AM
jmccart
15
01-26-2008 09:32 PM
jmccart
01-26-2008 07:36 PM
Patriot_RAM
10-08-2004 06:10 PM
Quick Reply: boost gauge for fuel pressure
