boost at cruise????
boost at cruise????
I've got a buddy at work asking me this so I figured I'd pass it on to you guys. He has a 95' 2wd ex cab 5 speed. Just the regular pump tweeks, advanced timing a little, 4" turbo back, BHAF, and cross drilled exhaust housing. He says at 65mph he is running 10psi on flat ground at 570* egt. The boost sounds a little high to me but then again I dont have a second gen.
What do yall think, whats normal?
I run between 12 and 15PSI and 650 EGT at 75 to 80 MPH.I heard that rear gear ratio will also make a difference(lower boost and EGT with higher gears).I have 410 in my truck.Looks about right for his truck..
trophystock
07-06-2006 06:28 PM
Palmetto_kid
01-16-2004 02:21 PM
