Blown Slave Cyl.
Blown Slave Cyl.
HELP, I was sitting at a red light pushed in the clutch and bam felt like somthing broke, I had to start the truck in gear to move it to a empty lot and found the resivoir for the clutch dry put fluid in it and it started comming out if the clutch , got the truck home called and found a slave cyl only, pulled out the master cyl , slave cyl, and res installed the slave cyl put all back in the truck tried to bleed the system but the fluid level wont go down still no clutch, HOW DO YOU BLEED THE SYSTEM?
GR40RCapri
16
01-18-2007 02:07 PM
Fishbait
06-06-2006 12:34 PM
cummer01
05-27-2004 04:07 AM
