Block heater failure ??
Old 02-14-2009 | 11:02 PM
TRCM's Avatar
I had a post a few weeks ago about it.
YES !!! My truck will not start if it is below 40 deg outside unless it has been plugged in.
Old 02-14-2009 | 11:23 PM
TRCM's Avatar
Originally Posted by Fueling around
0.65 kw/hr X 24 hr= 15.6 kw. At East coast rates of around 15¢/kw-h and 30 day monthly average it adds up very quickly to your $100 bill.
Still doesn't fully add up to the 20kw delta you noted.
There may be some leakage on the circuit you use to power the block heater.
I=V/R If resistance goes up the amps go down. A similar inverse relationship as intelligence & common sense?
and the cost of fuel vs how much I drive
Anyway, around here, the cost is 8.5 cents kw/hr, so...
Currently, I am using (.167 kw/hr x 24 hr) * 30 days *.085 / kw = $ 10.22 for power (which when all the taxes & crap is added in gives a bill of about $35)
With the truck plugged in, it is (1 kw/hr x 24 hr) * 30 days *.085 / kw = $ 61.20 for power (add in all the other crap, and it should be around $76)
For the month of dec the garage used 2x the power that my house did !!!!
Old 02-15-2009 | 08:37 AM
blackimpala's Avatar
I think there is something else wrong with your truck if it won't start in 30* weather. I live in Wa. and don't plug mine in intill it gets into the teens.
Floyd
Old 02-15-2009 | 08:45 AM
TRCM's Avatar
Read this, it will explain the other problems
https://www.dieseltruckresource.com/...d.php?t=230425
Old 02-15-2009 | 09:25 AM
Valv's Avatar
At this point I think you better chalk off the block heater too.
No grids, no solenoids, no compression. I think you might want to look into some repair. Electrical bill only will cost as much as the solenoids, next month it will pay for the heater (used), the next month again will pay for the block heater.
I am sorry compression is not fixable with monthly electric savings.
I would not plug it in again unless you call an electrician, you might set your whole house on fire.
Old 02-15-2009 | 12:20 PM
dc10freighter's Avatar
I had the same problem with my block heater. It started when we moved to Alaska. I plugged the heater in, and it didn't seem to help, I looked at the GFCI and it popped it. In my stupidity I thought it was probably a bad GFCI so I plugged it in to a regular outlet. No problems untill we got our electric bill, holy cow it doubled.
We went through a warm spell and I didn't plug it in for a week, and next time I plugged it in it quit working. I checked the resistance on the plug, and it just wasnt right, it shorted the plug, checked the resistance on the block heater and it was like 20 M Amps. I pulled the heater out of the block and it was very corroded and most of one side of the heating element was gone. I guess thats why the reisistance was so high. 40 bucks later a new block heater and no problems now.
From what I have read the resistance on the stock heaters from Cummins should be around 18 Ohms, if its not around there it should probably be replaced.
Hope this helps.
rjm022
12-11-2019 09:17 PM
IPDiesel
07-29-2015 09:57 PM
dodgetrucker75
03-17-2011 09:15 PM
supersonictoys
11-08-2008 09:17 PM
Reelay
12-01-2005 06:14 PM
Quick Reply: Block heater failure ??
