Barring Tool
Old 01-28-2007 | 03:21 PM
Harold Swanson's Avatar
Barring Tool
Where do I get one?
Old 01-28-2007 | 03:56 PM
butchb's Avatar
Talking
I got K-D Brand in a pretty cool Cummins Tool Set. It included a flex 3/8 drive ratchet, metric sockets commonly used in servicing a Cummins B series engine, a 14mm and a 15 mm wrench,feeler guages, a stubby screwdriver, an oil filter wrench, a BARRING tool, all housed in a nice case.
It cost about $55 and the Cummins part # 3399869.
If you just want The barring tool only do a search on e-bay.
Old 01-28-2007 | 05:40 PM
wheelo90's Avatar
When I adjusted the valves on my pickup, I did not need a barring tool to turn the motor over.
I pulled the inspection plate off the bell housing, and turned it over with a screw driver. Not very fast, but cheap to do and gets the job done!
Wheelo
Old 01-28-2007 | 07:28 PM
infidel's Avatar
Even easier just turn the alternator pulley nut.
Problem is you can only turn the engine one way (nut tight)
I made my own barring tool by welding the gear from a bad starter to a cheap socket.
Old 01-29-2007 | 12:18 AM
DL1221's Avatar
Here is one from SnapOn:
http://buy1.snapon.com/catalog/item....re&dir=catalog
I think Miller's version is slightly cheaper (Part No. 7471B), you have to call them to order it:
http://www.miller.spx.com/
I like these barring tools because you have very precise control and its really easy to turn the engine in either direction.
Old 01-29-2007 | 09:01 AM
SoTexRattler's Avatar
IIRC, I paid ~ $22 for the barring tool alone from one of the Cummins shops down here in STX. It was in a Cummins bag, with a Cummins PN(probably made by Miller).
Just go down to the Cummins parts counter and ask for a Barring tool for B and C engines.
I like the idea of that kit that BUTCHB described...
K.
Old 01-29-2007 | 04:07 PM
JKM's Avatar
JKM
Just like SoTxRattler said , cummins is the cheapest place i have found to buy the barring tool.
moparfan
01-28-2021 11:06 AM
snic
15
06-14-2017 11:29 AM
fordsux8269
05-16-2006 12:49 PM
keithplacervill
12-24-2005 08:53 PM
Pureliving
07-21-2004 05:42 PM
Quick Reply: Barring Tool
