banjo bolt
banjo bolt
where can i get a new banjo bolt... the one that is the feed line to the injection pump?
i drilled and tapped mine for a fp gauge a while back and i now have a plug in the tapped hole (no longer using fp gauge) and its leaking out the plug..
would like to just get a new banjo bolt and 2 new gaskets while i'm at it.... where can i get these?
anyone have part numbers?
http://www.recreationalmobility.com/...ion/24747.html
If you remove the guts from an old overflow valve it will work too.
