bad u-joint a problem to drive on?
Old 04-28-2008 | 11:12 PM
AmadosWorker's Avatar
I have a bad u-joint in the front axle. I have been driving around with it like that for months. Just wondering how important it is to fix this problem? What kind of damage am i doing? Should i replace all u-joints and ball joints when i decide to repair?
Old 04-29-2008 | 07:23 AM
Bersaglieri's Avatar
I drove on mine for a few months too. As long as the caps arent gone inside the yokes you'll be fine. If not it could be causing damage to the yokes $$. You dont need to remove ball joints when you do this. Just press the hub assembly off and slide the axle out. Mine took me a whole day taking my time. But I also did pads, rotors, calipers, etc.
-Dustin-
Old 04-29-2008 | 09:18 AM
bob95065's Avatar
if you continue to drive with a bad outer u-joint you will ruin the axle seal.
Old 04-30-2008 | 02:14 PM
chariotdriver's Avatar
Seals
That's right, when the yokes start wobbling due to u-joint play the seals will fail. The right one is pretty easy to change----the left one requires you to drop the differential which riquires you to pull the right side/yoke assembly out as well. I hope it's your right side sd
72dart
06-19-2012 10:42 PM
wcbcruzer
22
04-30-2008 06:58 PM
FDC
07-16-2007 12:51 PM
Treangen
05-07-2007 03:10 PM
C Pierce
03-21-2005 08:41 AM
Quick Reply: bad u-joint a problem to drive on?
