Axle swap help
Old 09-10-2007 | 10:59 PM
Dodge359's Avatar
Axle swap help
I am swaping a 4x4 front end into 2wd that has a solid front axle. All the measurements are the same so it will just be like swapping for the same axle. My question is: After I unbolt the track arms, steering, shocks, brakes and everything else does the frame just lift off of the coil springs?
Old 09-10-2007 | 11:05 PM
97' CTD's Avatar
Yup.
Brandon
ChargerLighting's Avatar
IF I'm reading this right...
As soon as you have most of the front end undone on the 4x4, the axle will just hang down & you can pick the coil springs out by hand.
Old 09-10-2007 | 11:12 PM
Dodge359's Avatar
I am actually trading the complete thing, housings and all. I need a 4x4 and I have a donor truck (Complete with a CTD for a back up, or for sale?) I will also be swapping trannys since the donor is a 98 and has the nicer shift tower that I can get a short throw shifter for.
Old 09-11-2007 | 11:44 AM
Box5's Avatar
if ur tranny is in good shape, just swap the shift tower. That way u know what ur trans is like already and wont have any suprises from the other one.
Old 09-11-2007 | 06:17 PM
Dodge359's Avatar
My synchros are gettin pretty thin and input is kinda chewed up from previous bearing stick.
Old 09-12-2007 | 05:50 PM
Dodge359's Avatar
Does the wires that run the 4x4 light that come out of the actuator break the ground or hot side of the circuit?
I am also trying to find the mechanical alternative to the vacuum switch. I looked at the POSI LOKs and they are nice but spendy.
crewcabxlt
12-26-2012 01:24 PM
rustydeeretech
17
05-21-2011 03:05 PM
ddestruel
06-05-2007 07:11 PM
04ctd
04-05-2005 11:59 AM
Paul Winey
06-22-2004 08:09 AM
Quick Reply: Axle swap help
