Auto to NV4500
Auto to NV4500
Who has done this conversion? I am ready to order some parts.....looks to be simple and straight forward:
Clutch pedal assy and linkage
master, slave and hyd line
floor plate, shifter and boot
minor wiring conversion
early 2nd gen ext hsg w/t-case shifter mounting lugs
replace 23 spline head gear in T-case with 29 spline gear
reman 4500 w/5th update and full spline shaft
SB Con OFE 13"/1.25 conversion kit w/wheel and release brg
Bell housing and shift fork
crossmember adapter for trans mount on stock member
Anything I'm forgetting?? I haven't figured out yet if the driveline will have to be changed out.
Thanks guys
Thanks guys
Thanks Vordie.......between writing this and just a few minutes ago, I found a wrecked '01 HO 5600....dirt cheap. Of course you know what I have brewing now.......
But if it doesn't work out, then I will need a Manual trans adapter plate eh?
I would not mind converting to a six speed, the only problem is that you have an extra gear to go through to achieve the same top end speed as a 5spd "no help on topend"
SmokinFive9 4x4
17
09-29-2005 07:08 PM
