anyone using water meth?
I want to put a water methanol kit on my truck, what is the best kit for a 12 valve? I dont want one that comes on at high boost cuz thats not when my truck runs high E.G.T. the temps are toasty at 10 psi. pulling hills. is there a kit that can be turned on with a switch or button?
somis:
I am running a "Scheid Water Injection System" in my 1996 Dodge CTD 12 valve, but it is probably "overkill" for what you are looking for. Before I got this system, I had a "Snow Water Injection System" and it worked well before I got up real high in H.P. and TQ. There are many Members here that have the water systems on their trucks and hopefully they will post here for you.
Some of the other name brand systems are:
Coolingmist Water Injection
Painless Water Injection Systems
DevilsOwn Water Injection System
I would suggest taking a look at our "banner advertisers" at the top of the page for more info or go take a look in the DTR Store also.
John_P
I am running a devilsown kit and it cools great but my truck is a cr so the timing is variable. Like John_P said, Snow is good but I like Devilsown due to the in cab adjustablty. I am running big nozzles so 10 psi does not work for me I have the pump start at 17 psi and full on at 35 psi. you can get kit that use hobbs switches set at any psi. get a kit and play with nozzles sizes to see what helps you the best.
nitrous
06-13-2010 11:17 PM
jdpiii
06-19-2008 07:34 AM
LanceD
21
04-06-2007 09:31 AM
