Anyone running a coolant filter setup?
If so, what are you using and how do you have it plumbed in? I've been pushing the idea around of putting one in somewhere down the road.
coolant
You won't find any ISB in trucks commercial or Dodge with a coolant filter , now if you had a liner equipped engine such as the ISC and bigger engine , you will find a coolant filter for liner protection.
I have been running a filter for about the past 10000 miles. I used the Fleetguard cartridge that does not add any DCA additives. It is just a filter cartridge as per the advice of the people at Fleetguard. I used the spin-on cartridge adapter for the filter and set it down in the hole on the pass side between the battery, the radiator and coolant recovery bottle. I could not find a good place to mount it with a bracket so just stuck it down there. It works fine.
For plumbing, I used 3/8 push lock hose with JIC -6 fittings. I used the 1/2 bung on the block behind the alternator for water in, and I added a a hole to the elbow where the water from the radiator goes into the pump down above the A/C compressor for water return from the filter. It made a clean setup with proper circulation.
So far, the coolant has stayed clean and bright, and there is reduced scale buildup in the system.
Originally posted by Dr. Evil
You can probably get the same result by running Evans Cool waterless coolant.....has a higher boiling point and eliminates corrosion.
Re: Anyone running a coolant filter setup?
jesussaves
01-02-2011 08:20 PM
CTDHokie
08-16-2004 12:03 PM
