Any Probs Running Jet-a In A 12 Valve???
Anyone here have any problems running jet-a fuel in their trucks. Know a guy who ran it in his powerstroke but would mix automatic trans fluid to aid in lubricity. Can I hurt anything on a 12 valve running this slim to none lubricity fuel?
I spent 36 years dipping sumps on heavy metal and dumped a lot of jet A into the waste tank. I never used it in my vehicles but I knew of guys that did, they just added a little oil to it be it 2 stroke or engine oil. NOT jet engine oil.. Diesel was always cheap and at the time it wasn't worth the mess, but now it's $1.10 or so a liter it's a different story. Go ahead and fill your tank.
He said add 2 stroke oil that is made to lube fuel systems, DO NOT put jet ENGINE oil in your tank. The manual says Jet-A is fine up to certain amounts if not mixed with lube but if you put lube in it it should be fine.
Here's some info from Dodgeram.org.
"Using Other Fuels in a Ram Diesel
For the "inline" P7100 pump ('94 to 98.5 12 Valve engines). P7100 pumps are internally lubricated by engine oil.
These fuels are "OK": #1 & #2 Diesel, 1K & 2K Kerosene, Jet-A, Jet A-1, JP-5, and JP-8.
NOT OK under any circumstances: Jet-B, JP-4, and Cite
The "rotary" VE pump (pre '94) and electronic VP-44 (98.5+ 24 valve) VE and VP-44 pumps are fuel lubricated.
#1-D Diesel or #2 Fuel Oil (diesel) only
Alternate fuels listed for the P7100 pump may be used in the VE pump if if 5% lube oil is added.
The P7100 inline pump is internally lubricated by engine oil, while the VE and VP-44 pumps are fuel lubricated. The "lighter" fuels, such as Kerosene, Jet-A, and JP-5/8, don't lubricate enough.
Note: there have been some reports of sticking plungers in some early P7100 pumps. There are many commercial fuel additives which contain a pump lube - to avoid plunger trouble, consider using an additive when the engine is running on an alternate fuel.
Fuel Tidbits from the Bradley Bits - a news bulletin for Bradley Fighting Vehicles
JET A-1 fuel is essentially identical to JP-8 except it does not have three additives required in JP-8: a fuel system icing inhibitor, a corrosion inhibitor, and a static dissipater additive. Hot JP-8 fuel reduces the life of fuel pumps on some diesel engines, so avoid using JP-8 or Jet A-1 extensively in hot heather, and keep the fuel tank as full as possible to reduce fuel temperature.
Diesel fuel #2 and water separate completely; JP-8 fuel and water do not. JP-8 becomes cloudy when contaminated with water; and the cloudier the fuel, the more severe the contamination. The Ram fuel/water separator will not be able to remove suspended water from JP-8 or Jet A-1.
Some Questions answered by Josh Berman of Cummins:
> Dodge says to run #2 diesel under most conditions. In "arctic" conditions (<10 °F), others
> recommend 50% #2, and 50% K1 OR #1 diesel. Is the 1st statement true? I know the second
> is because its in the owners & service manuals.
Blending is better than running on fully on #1 or K1, because it will keep your power output closer to that of running on #2 Diesel.
> What if any problems will be caused by extended operation on other than #2
> diesel? I'm more concerned about short duration needs... ie out in a rural
> area and unable to find diesel, but can find a K1 pump.
If you have a '94 to '98.5 12 Valve truck, then you should have no problems running a tank of K1 (2K Kerosene, Jet-A, Jet A-1, JP-5, or JP-8) through your truck. You might find that it performs differently (ie: #1 Diesel gives lower power than #2 Diesel), but it should not cause any damage to your engine. (Note: Jet-B, JP-4, and Gasoline are NOT to be used in any models. Dave)
However, if you have a 1989 to 1993 Ram or a 1998 and up 24 valve engine, then we DO NOT recommend using any fuel other than #1 or #2 Diesel. In an emergency, you can use 1K or 2K Kerosene, Jet-A, Jet A-1, JP-5, or JP-8 ONLY IF YOU BLEND 5% NEW LUBE OIL with the fuels (ie: 20 gallon fill-up, add 1 gallon new lube oil). Adding the lube oil is VERY IMPORTANT, as running on the lighter fuels without additional lubrication will cause excessive wear in your fuel pump, which is not a warrantable repair.
CAUTION: Running fuel other than #1 or #2 diesel w/5% lube oil should only be done if there is ABSOLUTELY NO OTHER CHOICE. Fuel pump damage due to inadequate fuel lubrication IS NOT COVERED BY WARRANTY, we don't recommend "lighter fuels + 5% lube oil" unless you're in a really desperate situation."
Jet engine oil (turbine oil) be it Castrol 5000, 2380, 254, Mobil Jet 2, are made to MIL-L-23699C or MIL-L-23699E which has a MINIMUM flash point of 475 deg F most newer oils are higher, Mobil Jet 2 is 545 deg F. On start up my idle temps are around 250 deg F, I know thats not in the combustion chamber but... The high flash point alone would stop me from using it. While all these oils are a SYNTHETIC ESTER BASED LUBRICANTS its what each manufacturer puts in as chemical additives that will not only destroy rubber lines and seals very quickly but are not designed to be burnt at low temps, you would have no idea what is coming out the tail pipe.
From: Ordered to Elizabeth City NC. rather be back in north Idaho
So I guess I could mix a few gallons of JP-5 in with a tank of #2 diesel to take my $100+ per tank just a little further (with a little 2 cycle oil of course)?
Cost/benefits of jp
The truck will start easier, the fuel won't gel up until about -40*C, and you won't need any fuel heat for de-waxing the filter. You will probably get about 10% less miles/gallon. It's quite a bit more refined and some of the energy has been removed as well. It weighs about 0.2#/gallon less than #2 diesel. Good luck and you don't need to mix anything with it, we use it in the air force trucks and ground equipment all the time.
