Another KDP Question
Old 01-24-2005 | 10:46 PM
kevellis32's Avatar
Question Another KDP Question
I Have been reading alot on the KDP and I cannot figure out exactly where the case is that I would need to take appart to get to the pin. Can anyone give me a heads up on exactly what and where i need to go on my truck to get to the pin. I've got the jist of what to do once i get to the pin but i just need to know what to take apart to get to it. Thanks
Old 01-24-2005 | 10:58 PM
fschiola's Avatar
See if this is of any help.
KDP fix
Old 01-24-2005 | 11:04 PM
kevellis32's Avatar
Thank you very much, that definetly will help, any ideas on the approximate time it will take to fix?
Old 01-25-2005 | 05:42 AM
fschiola's Avatar
I would think it should take a couple of hours maybe.
Old 01-25-2005 | 06:47 AM
BBWD's Avatar
The KDP fix described in Fschiola's link is the "tab" method.
You can also contain the KDP using the retaining bolt method if the KDP has not started to work it's way out. This method does not involve removing the timing gear cover. Using a jig, a hole is drilled through the front gear case cover, the hole is tapped, and a bolt is inserted in front of the KDP to prevent the KDP from backing out. This is the way I "killed" my KDP.
Just wanted to let you know that there is another method. This method is a lot faster IMO.
The advantage of the tab method is that you can see if the KDP has moved, you can snug up other bolts while you are in there, you can fix any leaks you may have with the gear cover, and you get to replace the seal in the gear case cover.
John (DH)
Old 01-25-2005 | 07:17 AM
Flashdancr's Avatar
Take a look at Pappyman's site.
http://www.phantomcycle.com/kdpfix.html
Old 01-26-2005 | 08:35 AM
mx261's Avatar
I just did my pin and it wasnt bad at all. My wife did most of the work!! We tabbed it and put it back together. done deal, now if can just get her to put in bigger injectors........
Old 01-26-2005 | 09:02 AM
kevellis32's Avatar
Where is a good place to find that jig set that is on that webpage about how to block it with a screw
Old 01-26-2005 | 09:20 AM
mx261's Avatar
the bad part about the jig set up is that if the pin has worked its way out just a little then you will end up tearing it down anyway. I didnt even have to get any gaskets as mine were in good shape and it hasnt leaked. I was just very careful when i took everything apart and put it back together.. Heck, if you want you can give me a call and i can talk ya thru it. let me know
Old 01-26-2005 | 10:02 AM
infidel's Avatar
Contact Harold- rvhvnfn@juno.com -208 850-8749
Harold has a standard kit consisting of the KDP jig, a 5/16 drill bit w/drill guide and stop collar.w/directions for $29.95 including S&H.
He also sells fan wrenchs, not sure of the price.
Even though Harold sells the jigs he now recommends the tab method.
sootnsmoke
01-05-2012 08:55 PM
Smokin96_12v
10-12-2009 07:39 AM
Jezzhuntin
08-25-2006 02:51 PM
ade's ram
27
01-13-2005 03:51 PM
gofastman
03-19-2003 10:29 AM
Quick Reply: Another KDP Question
