Amsoil MTG in NV4500, experiences?
Has anyone been running this lube in their NV for a significant amount of time, say 100k? Anyone replace the syntorq in a good used trans w/ amsoil as maintenence? Just wondering what everyone's experience w/ this lube is. Thanks
I have been running MTG is the 4500 on my 2001 for just over 120,000km
No issues to report, no hard shifting, no accelerated wear problems, just smooth operation, and less than 1/3 the cost of syntorque.
It's your money, your truck. I just changed my fluid out, and bought the Syntorq, big bucks, but it's like a new transmission now. There is NOT a substitute fluid out there that meets Syntorq's exact specifications FWIW.
I just installed a Torque King kit and refilled with the Amsoil... Its been about 1000 miles and I have to say im not a big fan. Though it has been smoothing out, when everything is warmed up, the shifts are slightly notchy and the transmission is noisy when its spinning with NO load on it, such as at idle in neutral or coasting in neutral both with clutch engaged.
I am going to give it another month and if I am still unsatisfied I will be replacing with SynTorq.
I liked Royal Purples GL4
There have been two people I know of whose syncros were eaten by Royal Purple and trannies had to be rebuilt.
Bet there are plenty more out there who used it and don't know what killed their tranny.
I wouldn't use it.
I first switched to Amsoil about 2 years ago and it was done (dare I say) in a lube shop. They vacuumed the syntorq out and refilled with Amsoil. It did improve the shifting for awhile but I wasn't happy. So I drained the Amsoil out by removing the side plate then cleaned the gearbox out properly, which is what should have been done the first time. Anyway after refilling with Amsoil it was a completely different gear box. While the Amsoil lube was not available when the truck was built, Amsoil does say it is for use in the NV4500 and they stand behind it. Works for me.
Luckily my Auto comes next week.
I only put 300 miles on the royal purple, its now in a 5 gal. bucket, and the trans is on its way to its new owner.
The RP is GL4 rated.
SCARY thing is Blumenthals says to run a synthetic 80/140 gear oil
