Alternator may be going out??
Every morning I start my truck my volt meter suges up and down. My headlight go bright then dim for about 5 minutes. Then the volt meter stays put the rest of the day. Only happens in the morning... I am thinking bad voltage regulator? But it is stange it only happens the first 5 minutes of each morning???
Dave
Dave
Dave
Dave
does not have an external regulator, Least mine didnt, voltage regulation is controlled by PCM, if this is a failiure, some have had good luck with putting an external regulator, and others (myself mainly ) have not had good luck, after much debate and more stuff going out i said to heck with it and got the PCM, no more problems since, but at over 600 bucks i can assure you thats money that hurts to let go of....
Tx
5.9Excursion
03-13-2008 07:08 AM
Bart Timothy
05-04-2006 04:53 AM
