Alternator brushes?
Alternator brushes?
Any ideas of what the average lifespan is for the OEM brushes is for a 1996 TCD? The alternator is stock and never been touched. I know that there is no set mileage, but I am looking for a general consensus. Nothing I will hold you too
Mike
Mike
That's right around where I've seen the failures too. If you catch your alternator before it fails, replace the brushes and clean up the slip rings a bit, it should last a good long time without letting you down. Mine failed a couple years after I replaced the brushes, stuck a new rectifier in and it has been good ever since.
I just pulled my original out of storage and took it in to my local rebuilder for freshening up. It's Nippo Denso! Can I assume the N.D.'s are much better than the generic alternators you get at the auto parts stores?
pw58
12-05-2011 11:40 PM
Blackhawk
08-16-2006 06:32 AM
