Air ride Suspensions??
I was looking into a lift kit like fabtech for my 97. After some info on drive angles from sled pulling(not doing alot of it at all) now i'm considering a air ride suspension lift, but know very little about them. Wanting some input. On the plus side, it would add to the cool factor.
A manufactured lift will not give you any issue if properly installed. If you are worried about drive line angles, a air ride system can make things worse. As you adjust ride height, you are changed drive line angles. Which causes vibration. Plus don't forget, if you are going to a true air suspension system. You are will have to change the rear to a four link.
BUFF_dragon
02-25-2008 08:49 PM
