aftermarket transmission lines with port for gauge sender?
That bottle , is the heat exchanger.
I replaced most of my lines with hydraulic hose, with JIC ends , I modified my stock fittings by brazing in a JIC end, then installing it back into the transmission and heat exchanger. I re-used the stock lines going to the cooler , but had them flared and a JIC nut installed, so i could mate a hydraulic hose to them, all of my connections are now JIC. Pictures below:
Heat exchanger:
Jic compression nut on line to cooler:
Hot line from converter , great shot of modified fittings:
Oil return to tranny:
JIC nut on oil return line:
And finally where i mounted my gauge sender, i would have run two tees inline , but the stock wiring for the stock sender would not reach, and the location had to be changed due to space constraints, i could not leave it in the stock location without a huge conglomeration or hydraulic fittings. It may be hard to see the sender in the picture , it is pointing up and to the left.
If you have any questions , just ask me.
Heat exchanger:
snowmanx
06-06-2010 01:53 PM
Teach
04-11-2007 06:28 PM
QWKRTNU
09-26-2006 10:22 PM
edge600
03-12-2006 10:15 PM
