afc housing repairable?
pulled off my afc to find this. threads are stripped and the housing is worn from rattling around there a while. I will be replacing it.
anybody have a spare? or thoughts on where i could get one?
17mm sounds big, I want to say it's m14x1.25...
Take it to a local Napa, hydraulic shop, hardware store etc to match the threads up. If the housing threads are damaged you may be able to repair with heli-coil. May need a bottom tap, not sure how much room there is without hitting the diaphragm.
Or tap to the closest size SAE pipe thread (1/4"?) and dig for a fitting(s) to plumb the small lines back.
royta
02-15-2005 10:15 PM
halerazor
06-14-2004 08:45 AM
