advice requested
advice requested
I getting ready to pull the bed off my 1995 4x4 extended cab 180k miles. I need to fix the sending unit and I want to replace the the fuel lines and touch up some surface rust. My questions are, should I replace the clutch, I have no issues right now, just thinking while I have easy access does it make sense at 180k miles?
Also, Advanced Auto brand is "Perfection Clutch Set" and its on sale for $219 is it a reliable brand and worth the $$.
I do a lot of road driving 98%, occasional hauling.
TIA
Jeff
TIA
Jeff
If it isn't slipping then why replace it? A $219 clutch set won't last as long as whatever life is left in the one you have now. I learned from experience that a cheap clutch costs more in the long run than a quality clutch like South Bend. Two lifetime warranty clutch discs from Auto Zone and a "heavy duty" clutch from Blumenthals in OK City cost me labor charges and down time.
We install Luke clutches in almost everything. Have never had a problem with one. They have stock replacements and heavy duty sets. You can check them out at, http://catalog.schaeffler-aftermarket.us/
Randy
Randy
SFCHubie
10-20-2011 10:43 PM
PapaPerk
10-21-2010 02:10 PM
betsycam
08-01-2006 04:44 PM
redramnc
08-06-2003 07:30 PM
