Adjusting Valves
Old 10-22-2006 | 09:32 PM
wilderness's Avatar
Adjusting Valves
When should I adjust the valves on my truck. It seems like they rattle a bit under a load or when it's cold. I've got about 170k on the clock now.
Old 10-23-2006 | 10:46 AM
waldersha's Avatar
If they have never been adjusted, check them out. As long as you get them set right and tightened correctly, they don't need it very often. I have done mine twice in the 7 years that I've owned it.
Old 10-23-2006 | 01:39 PM
~Angry Tractor~'s Avatar
I seem to remember reading somewhere every 25,000 miles.
Old 10-23-2006 | 01:56 PM
bnold's Avatar
I thought is was every 100k??
Old 10-23-2006 | 02:28 PM
ccmckee's Avatar
I do mine once a year just 'cause.
Old 10-23-2006 | 02:29 PM
Lunyfringe's Avatar
you're both right.. (well, close)..
the 12V engine is every 24,000 miles...
the 24v engine is every 150,000 miles (135k on severe duty)
here's the procedure for a 12v, similar on 24v:
http://dodgeram.org/tech/dsl/valve_adj/12_valve.html
there are other methods- do a search for valve adjust or valve lash.. it's not difficult, when you get used to it, it's real quick... most of the time mine doesn't need adjusting, I check it, and they're dead on...
Old 10-23-2006 | 04:29 PM
JKM's Avatar
JKM
On a side not , some guys will set their valves at .008 and .018 , instead of .010 and .020, opens the valve a little farther, but still has lots of piston clearance.
marine4life
03-11-2006 08:36 PM
robox
08-16-2005 07:27 PM
CrewCabCummins
01-03-2005 04:29 PM
Denis
04-19-2004 12:32 PM
Puke
06-23-2003 01:06 PM
Quick Reply: Adjusting Valves
