Adjusting the star screw
Old 10-19-2006, 08:11 PM
Dodge@KY1997's Avatar
Its just the shifter, not the whole trans. I made a post about how I retrofited the shifter onto the factory shaft.
Old 10-19-2006, 09:08 PM
Willy91's Avatar
Originally Posted by Dodge@KY1997
It says on the TST page that i would have too high EGT and my clutch couldnt handle the #10, so how about the #12?
If you're fairly easy on it and drive like a sane person the 10 plate should be ok on your clutch. As long as you have a pyro, your eGT's will be fine.
Old 10-19-2006, 09:39 PM
Does everyone recommend the TST plates?
Old 10-20-2006, 09:04 PM
Willy91's Avatar
Personally I'd grind it myself, not very hard to do and will save you some$$$
Old 10-20-2006, 09:07 PM
Willy91's Avatar
Here's some pics of what a 10 plate looks like
Old 11-16-2006, 04:46 PM
b.lee's Avatar
Alright so I am kind of upset. I pulled off the blug and saw that the screw was almost to the very front of the housing so I can't turn it anymore. The only time this thing smokes is on start-up. Is there something else I need to do to make it smoke? I am going to change the fuel filter tonight in case that might be the problem....Any ideas?
I just did this today.
Yes, it looks like the starwheel is too far up but you can still turn it.
All you need is a small flathead screw driver to put in the teeth of the starwheel, turn it towards the engine for more smoke/off the line accleration.
Don't pry on the threads where the 8mm allen head plug screws in.
Old 11-16-2006, 05:24 PM
BigMackDodge's Avatar
off the starwheel topic.... Is no fuel plate a bad thing? I have heard both ways on this. I am just seeking more insight. Thanks
TXlilbro
07-16-2010 10:05 AM
Brendan
09-25-2008 03:27 PM
ofcmarc
11-03-2007 01:34 PM
colofred
04-22-2007 09:49 AM
Brendan
14
10-30-2006 11:21 AM
Quick Reply: Adjusting the star screw
