adjustible ball joint , #s
Old 12-14-2006 | 02:31 PM
John Faughn's Avatar
Looking for source for quality ajustable ball joints , have that there are better allinment spec.s for our trucks if you drive with some load most of the time .
Thanks John
Old 12-15-2006 | 09:10 AM
WVAussie's Avatar
Man this is not a popular topic. I have pretty much the same question on the other page and no answers.If you find any good info let me know.
Old 12-17-2006 | 04:19 PM
There was an artical in the TDR mag. ,# 53 , talked about better alingment specs. if you drive at least partly loaded most of the time .
for are yr mod , 94-99 , Ingall's Engineering , in Col. , Part # 532 or 532000 ,
I checked at the 1st non do-it-yourself parts house , they said that they had at warehouse , and that it was an adjusting sleave , so I asked about a coresponding ball joint to go with , since they said it was just a sleave , have to wait till weekday to find out more .
A couple braincells fired and the thought came to google them , ph.# 1-877-858-7272 , I checked the site and the numbers did not match , looked up by apl. and said LD with part # , so I'm thinking that means light duty , dana 44 , so still in the same boat , mon. to find out .
Old 12-19-2006 | 08:39 PM
corn binder's Avatar
ok everybody. what you are looking for are adjustable camber sleeves. they are slotted so the caster/camber can be adjusted. from the factory they are set at one spot and the only thing that can be adjusted is the toe. go to napa or carquest and ask for them, if they say there aren't such a thing insist to look threw the suspension book, that's what i did. my 94 ford f-250, has adj. camber sleeves and i just bought them last week for my dodge. later, pete
Old 12-20-2006 | 08:21 AM
WVAussie's Avatar
Does your truck have a D44 or a D60. The parts places are telling me that they are not available for the bigger axle.
Dane
12-17-2011 03:30 PM
rootkit
05-15-2011 09:18 PM
wcbcruzer
22
04-30-2008 06:58 PM
FDC
07-16-2007 12:51 PM
Treangen
05-07-2007 03:10 PM
Quick Reply: adjustible ball joint , #s
