AC and idle problem
Old 07-21-2016 | 01:02 AM
AlpineRAM's Avatar
Vacuum problem causes your"defrost only" situation.
Idle speed should be between 750 and 850 rpm AC on, transmission in D - a lot are set too low and that causes a bunch of problems
Old 07-22-2016 | 08:07 AM
patdaly's Avatar
Vacuum comes in a single line from the vacuum pump in front of the PS pump and runs to the drivers side of the cowl. There it Tees off to the various locations. It is VERY easy to get it disconnected at the T even with a simple job like changing the fuel filter.
I would say 90 percent chance you will find it between the pump and that T.
Old 07-22-2016 | 08:28 AM
pipefitter's Avatar
Mine had the funny idle problem as well. It would lope like it had an aftermarket cam when idling in drive with the AC on, and the idle speed was probably around 450-550 rpm. It would cut off if I let off the throttle suddenly, like in parking lot situations. The idle adjustment screw is a bit tricky to locate. It's on the driver's side, towards the back of the engine. There are some videos of this task on youtube.
banks twinram
05-18-2010 08:10 PM
kicker210
12-02-2009 08:23 AM
freds89
05-07-2009 08:54 PM
BPD239
13
03-24-2005 09:12 AM
jimjawz
01-20-2004 11:16 PM
Quick Reply: AC and idle problem
