'98 RAM 2500 VIN 6 Cummins; location of oil pressure sender
Hi, I'm hoping someone can tell me where the oil pressure sender is located on this engine. I have an oil pressure gauge giving irratic readings at idle, and have already purchased a new sending unit, but for the life of me I can't find where the thing screws into the block. Must be stuck back in a corner somewhere.
Thanks in advance.
Thanks in advance.
You can probably see it if you look over the top of the drivers side tire. Also, a couple of long extensions and you can probably change it from there.
Welcome to DTR!
Welcome to DTR!
hotrod929
12-03-2009 07:10 PM
