98 auto transfer case on a 47rh- will it work?
Old 10-19-2012 | 07:31 PM
Mopar1973's Avatar
friend is looking to buy a 47rh and has a transfer case from a 98 auto truck, should be able to use the tcase on the 47rh right? thanks in advance
Old 10-22-2012 | 01:50 PM
dieseldemon's Avatar
As long as they are both autos will work
Old 10-22-2012 | 04:53 PM
gorms's Avatar
The 98's don't have a speedo sensor in the transfer case tail housing, not sure if that will be a problem for his application or not. The tail housing can be found for relatively cheap from a junkyard, 1/2 ton t-cases I THINK have the same tail housing as long as the 241 is not an HD.
Old 10-23-2012 | 05:15 PM
What truck is this going in?
Old 10-23-2012 | 09:25 PM
Mopar1973's Avatar
its a 1999 24v with a 97 12v in the truck and the transfer case does in fact work. Electronics for trans were removed prior to my installation of trans and NSS is bypassed.
wyododge
08-18-2011 07:48 AM
big stinky
05-16-2011 08:35 AM
csramsey640
07-06-2006 04:44 PM
Quick Reply: 98 auto transfer case on a 47rh- will it work?
