98.5 come with 2 different fuel injector pumps?
Old 10-05-2006 | 10:15 PM
samasaurus's Avatar
I thought i read something where they came with two diffrent pumps. or was this just due to the difference in the 12v and the 24v? thinking about buying a 98 12v.
Old 10-05-2006 | 10:35 PM
TxDiesel007's Avatar
I think ur mistaken
But ill clarify this for ya, THe 12 valve has a mechanical lift pump, and the big injector P pump on the top. The mechanical lift pump can be found right by the fuel filter housing and heater assembly on a 12 valve.
The 24 valve has a VP44 injector pump, and an electric lift pump too, i think somewhere along the same location lines as the 12V engine..
So both trucks have two lift pumps, you can however, get a Fuel Air Seperation System, (acronym FASS) or a pusher pump if you have a 24 valve tho to better fuel ur application... no need to do such thing with a 12 valve...
Rick
Old 10-06-2006 | 02:57 PM
CTD NUT's Avatar
98 = 12v with P7100 mechanical injector pump, cam driven lift pump
98.5 = 24v with VP44 electronically controlled injector pump, block mounted electric lift pump
redsealdodge
31
12-07-2007 05:22 PM
andyr354
08-15-2006 11:05 AM
Quick Reply: 98.5 come with 2 different fuel injector pumps?
