97' puppy how much H.P if stock plate slid forward?
Old 12-27-2002 | 06:28 PM
whiteknight's Avatar
any comments?
Old 12-27-2002 | 06:35 PM
pappyman's Avatar
Re:97' puppy how much H.P if stock plate slid forward?
You'll gain more smoke then HP if you tweaked the plate and the AFC adjustment on a good day down hill maybe 10 more horse's with no other mod's
Old 12-27-2002 | 06:55 PM
Eat Beef's Avatar
From: Alberta Foothills - Power to grow with 6 in a row - XLR8
WhiteKnight,<br>When I did that to my '97, this was the result.<br>K&amp;N air filter in the stock box<br>4&quot; exhaust from turbo back<br>Stock plate slid all the way forward<br>Mustang dyno- 225hp and 625 torque <br>The only problem was that I did not dyno the stock truck first for a baseline.<br>Andy
Old 12-27-2002 | 07:05 PM
ok thanks needs #11 i think. any more comments?
Old 12-27-2002 | 07:16 PM
pappyman's Avatar
[quote author=Eat Beef link=board=16;threadid=8858;start=0#85381 date=1041033306]<br>WhiteKnight,<br>When I did that to my '97, this was the result.<br>K&amp;N air filter in the stock box<br>4&quot; exhaust from turbo back<br>Stock plate slid all the way forward<br>Mustang dyno- 225hp and 625 torque <br>The only problem was that I did not dyno the stock truck first for a baseline.<br>Andy<br>[/quote]<br><br>That would be about right stock HP is 215 you gained 10 HP
Old 12-27-2002 | 07:32 PM
Monty's Avatar
[quote author=pappyman link=board=16;threadid=8858;start=0#85387 date=1041034561]
WhiteKnight,
Andy
[/quote]
[/quote]
He gained more than 10HP. Not too mention, look at the TQ number. The 215 number is FWHP....the dyno numbers were actual hp to the ground. Expect a 15-18% loss in hp thru the driveline.
Old 12-27-2002 | 07:54 PM
so its a little kick in pants
Old 12-27-2002 | 07:58 PM
pappyman's Avatar
[quote author=OkieBroncRider link=board=16;threadid=8858;start=0#85397 date=1041035577]<br>[quote author=pappyman link=board=16;threadid=8858;start=0#85387 date=1041034561]<br>[quote author=Eat Beef link=board=16;threadid=8858;start=0#85381 date=1041033306]<br>WhiteKnight,<br>When I did that to my '97, this was the result.<br>K&amp;N air filter in the stock box<br>4&quot; exhaust from turbo back<br>Stock plate slid all the way forward<br>Mustang dyno- 225hp and 625 torque <br>The only problem was that I did not dyno the stock truck first for a baseline.<br>Andy<br>[/quote]<br><br>That would be about right stock HP is 215 you gained 10 HP<br>[/quote]<br><br>He gained more than 10HP. Not too mention, look at the TQ number. The 215 number is FWHP....the dyno numbers were actual hp to the ground. Expect a 15-18% loss in hp thru the driveline. <br>[/quote]<br><br>Many times its is FWHP but after all the dyno runs Ive seen these CTD will put close to the same HP to the ground as the rated HP At the flywheel...because I was next door to the IHC dealer when I was thinking of putting a fuel plate in I dynoed my truck first...had 155 HP to the wheels (160 stock) after the plate I was 228 HP (230 HP plate)...Ive seen many times that diesels will put closer to the rated HP to the ground then gassers do for some reason diesel lose less HP thru the drive train I believe the torque that diesels have deliever the HP to the wheels better....IMHO
Old 12-28-2002 | 02:23 AM
Got Smoke?'s Avatar
I just moved my factory plate Full Fwd. the other day and its a very noticeable kick in the tail! ;D Definately more than 10HP, I believe I've read elsewhere that its between 20 and 40HP. 40HP sounds a little high, I'd say between 20 and 30 extra horsies.
Ordering my clutch next week!! Then I can get my #10 plate!! WooHoo 330HP/750TQ[glow=blue, 2, 300](to the rear wheels!)[/glow] here I come!
Actual BOMBing is a lot more fun than dreaming of BOMBing.
Old 12-28-2002 | 02:47 AM
gitchesum's Avatar
My 97 with just hte stick plate slid forward, and a K&amp;N puled a 283 RWHP on a Dynojet.<br><br>The same truck with a #10 plate slid forward and a 3K GSk and 370 injectors pulled a 405 HP a year and a half later. <br>My how things change. ;D
Old 12-29-2002 | 03:03 PM
OH  Sick's Avatar
Well........for what's its worth, my truck was 160 hp stock and a year and a haft ago I had the Cummins dealer slip my stock plate forward 40 thousands and he said that it netted me 40hp, 10 hp for every thou. So after I drove it I was satisfied to the point that I am not investing in another plate until I have a need for it. And It doesn't smoke. So what ever he did was well worth it if your the type that is looking for hp for dollars spent. 160 up to 200 for 50 bucks labor.
8)
Old 12-29-2002 | 04:28 PM
Monty's Avatar
What kind of EGT numbers are you guys seeing with the stock plate slid forward all the way? And, OH SICK, slid 40 thousandths?
Old 12-29-2002 | 07:18 PM
gitchesum's Avatar
Mine would only get hot at WOT in 4th and 5th gear. Otherwise they never got over 1100. I pulled a 35ft Avion 5th wheel through the hill country. Trailer weighed about 14,500. Never got over 1100.<br>
Old 12-29-2002 | 09:30 PM
DeereDiesel's Avatar
Mines all the way forward, and EGT's have never been over 1000 empty. Other day pulled a 26000 GVW load down highway at 65 and never over 1100. carty<br>
Dhorn33
16
09-23-2008 10:24 PM
TurboChris
11-04-2007 02:45 PM
JLo
12-07-2006 10:37 AM
lews930
10-27-2006 08:58 AM
mr T
32
03-07-2005 04:06 PM
