97 Filter drain
97 Filter drain
MY filter drain went bad and is leaking Air, does anyone know were I can buy a new one? . dealer said no longer available or if someone has a Cummins part # for it.
Thanks
Robert
Thanks
Robert
According to Cummins Quickserve the part is available. Unfortunately it does not show the part number, but there is a detailed blow-up of the filter assy. In fact it shows everything except the the head and the housing are for sale. FWIW the group number is 06.04 graphic number is ff943gb film card T
Isn't there just an o-ring and rubber washer that are replaceable?
Cummins and dealer might not list them as separate parts but I bet you can come up with what you need at a hardware or autoparts store.
Electronic Parts Catalog - Option Detail
Option Group Graphic Film Card Date
FF9142 06.04 ff943gb T 04-MAR-97
Engines G5.9, B4.5s, QSB5.9-44, QSB5.9, G3.9, B5.9 G, ISB CM800, ISBe CM800 (4 Cylinder), ISBe4 CM850 (4 Cylinder), ISD6.7 CM2150 SN, 6B, B6.7s, B5.9LPG, B LPG Plus, B4.5, ISB CM2150, ISB CM850, B Gas International, ISB6.7 CM2150 SN, B3.9, QSB4.5-30, B Gas Plus, QSB6.7 CM850, ISDe CM2150, 4B, ISBe CM2150, ISB4.5 CM2150 SN, ISD CM2150 SN, QSB5.9-30, ISF3.8, ISB CM550, ISBe4 CM850 (6 Cylinder), ISBe CM800 (6 Cylinder), QSB4.5 CM850, B5.9, ISBe CM850, QSB3.9-30
Ref No For-Sale Part Name Required
1 YES Screw, Hex Flange Head Cap 1
YES Screw, Banjo Connector 1
2 YES Screw, Captive Washer Cap 1
3 YES Screw, Banjo Connector 1
4 YES Hose, Plain 1
5 YES Washer, Sealing 2
6 YES Screw, Hex Flange Head Cap 1
7 NO Head, Fuel Filter 1
8 YES Element, Fuel Filter 1
9 NO Housing, Filter 1
10 YES Valve, Shutoff 1
11 YES Sensor, Water 1
For some reason I can't copy and paste the illustration, but here is the text. If the parts guy can find the filter element, he should be able to find the other parts.
4 YES Hose, Plain 1
Yup we both looked at that picture too. but ... they don't list a part# for it. but the good news is I was able to find the O rings in a HELP ( after going all over town lookin)package had to buy 2 to get the little fat suckers!
Mechanos
03-08-2004 02:30 PM
