97 Doesnt want to start after sitting
Old 02-13-2012 | 11:16 PM
9812vram's Avatar
Originally Posted by TheWaterman1000
9812vram,thanks for the info. Your layout looks different from mine. I have a 1994 Ram 2500. I uploaded a pic of it, waiting for approval. Now to fix the A/C. Only way to get cold a/c is jump the pressure switch under the hood. At least I can turn it on and off from inside the cab
Even on a '94, there should be a separate starter relay in the power distribution center as far as I know...
Old 06-01-2021 | 10:53 AM
Farmer_391's Avatar
1998 12 valve Cummins won’t start after sitting
So I have a 1998 12 valve Cummins that I ran all winter working and times before that started amazing always ran I decided to play with the fuel plate ran it for a bit then my oil cooler went fixed that then went to start the truck and it wouldn’t fire fuel issue which has happend when I had it sit before so I tried all the bleeding methods and then nothing. Had it running on five pistons then had a issue and shut it off. Didn’t touch it ahile after that but I replaced the fuel filter pumped it seemed to be going into the injection pump but it wasn’t starting barely and sound of catching I don’t know what’s wrong. Could it be injectors or injection pump? any help would be nice
kleinergti1
07-12-2006 10:47 AM
Katmandu
06-21-2006 12:33 PM
Pete Miller
07-19-2005 09:13 PM
livewire
10-13-2003 08:00 PM
Quick Reply: 97 Doesnt want to start after sitting
