97 3500 rear axel nut
Hi, I'm working on a 97 dually, replacing an Axel (hub) seal. Is there anything special I should know when torquing the nut? Thanks, Artie
Tighten nut to 120-140 Ft lbs while rotating hub. This aligns bearings.
Back off 1/8 turn. Readjust nut till .001 - .010 end play of hub is acheived. Overtighten or inadequate lube will cause great failure.
JImbo1
04-09-2003 07:46 AM
