97 12 Valve Oil Leak
Old 12-13-2011 | 09:13 AM
diesel yukon's Avatar
Originally Posted by donnymirage
Pulled head and the gasket is pooped. Little bit of compression leakage. Pistons are sure clean with the better injectors. Stiil seams imposible to me that oil could get out the passenger side without coolant or oil issues. Oh well shes purring again. Any Ideas as to why the gasket blew in short order. I'm suspecting the water meth. I forgot to mention that the timming was advanced a bit as well wich water meth apparently does not like. I have an AEM kit and was running 2 of the 550 cc tips. I swapped to one 550cc and one 315cc tips. I might pull it back to just the one tip. I did not notice a huge improvement with the water injection as far as power or egt's. It cleans the burn abit. I run the injection all the time and have it set to come in at 10 psi of boost. You go throuh the stuff pretty quick when towing. I'm hoping the new injectors will lower my egt's a bit.
I never ran my water injection that low of boost, my first stage would kick in at 17 pounds and stage 2 at 28pounds.Any low than that and It would kill the fire and the boost pressure would drop off.
Old 12-13-2011 | 10:45 AM
donnymirage's Avatar
Thats the highest setting on my controller. What sort of volume are you injecting
Old 12-15-2011 | 12:56 PM
I would have to look at the # on the nozzles I took out. When I was towing a trailer and the min. boost was 17 lbs. all day long it ratio's out to 30 gal. of fuel, to 5 gal. of water. But I live in very mountianest country also.
Old 12-15-2011 | 02:17 PM
I would estimate my usage at double that with the 550 cc nozzles. I would go through 5 gallons in about 250 miles. Verry steep hills around here though.
http://www.th.gov.bc.ca/popular-topi...de-profile.pdf
leekyle
06-22-2010 07:51 PM
tgroning65
05-27-2010 10:38 PM
george7941
11-28-2009 09:28 PM
donhov
26
01-06-2006 07:29 PM
Quick Reply: 97 12 Valve Oil Leak
