96 Cummins Freightliner FL60 Rollback
Old 08-01-2005 | 06:19 PM
trucksforu's Avatar
My rollback has a 5.9 cummins B motor Can antone tell me about the star wheel adjustment and turning up the pump for more power??? Also i have a overheating problem. Overheats the further you drive. Slowly creeps up. When left to idle,it comes down. Any help appreciated. Thanks, Gil
Old 08-01-2005 | 09:24 PM
59FORD's Avatar
Wait a minute............... your truck has a heating problem and YOU want to crank the
juice to it????
I will keep my opinion on the juice to myself since I have already killed 3 5.9ers all by lonesome.
Old 08-01-2005 | 09:57 PM
gerry's Avatar
I have an FL60 at work.. Had an overheating problem and at the same time there was an air his and the Airbrake tank would loose presure overnight.. I am by no means an experts on these trucks but I was told that the fan clutch is air operated and that it was failing causing an air leak... they replaced the Fan clutch and the airbrakes are holding pressure and the truck runs cool again.. As far as the Lift pump.. Only thing I know about it is they have to replace it about once a year... The truck doesnt get many miles on it but is runs 6 hours or so a day at 1,200 to 1,800 RPM's with a PTO Compressor and Backhoe.
Gerry
The Tank
Cummins Conversions
0
09-30-2009 07:22 PM
signature600
10-27-2006 07:52 AM
CJSamples
08-02-2006 04:28 AM
06dually
03-04-2006 08:28 AM
gman07
07-02-2005 10:10 AM
Quick Reply: 96 Cummins Freightliner FL60 Rollback
