96 - from 3rd to OD
96 - from 3rd to OD
stock gearing in auto trans.
4" exhaust, stock injectors, fuel plate to zero. adjusted timing forward, BD valve body, BD flex plate, boost elbow.
getting truck to highway speeds in a hurry. goes through 1st, 2nd and 3rd are fine. the transition from 3rd to 4th, the jump in gearing seems as if its to much of a gap.
the RPMs do drop quite a bit, not sure of how much off top of my head, but that sudden drop of RPMs and the ground speed of truck moving...does that pose a lot of valve pressure internally to the transmission?
I think the truck runs like a hot rod. i run it mostly unloaded. I do carry building materials, those times i don't hammer it.
You are probably feeling the TC LU, it is the big RPM drop. My 97 shifted 1,2,3,TCLU, then 4th.
TCLU was probably 500 plus RPM drop, while OD was only 200 or so. You will probably kill a TC sooner or later, but that's not because of too much pressure.
anonymous_1
13
04-30-2020 04:29 PM
buckman361
10-10-2008 11:23 PM
1qckdodge
03-05-2007 09:53 AM
tobyw
11-19-2002 10:47 PM
