95 12valve
Old 03-18-2010 | 09:18 AM
tompkinsgil's Avatar
95 12valve
when the truck is cold and you start it has white smoke once you drive it down the road a mile or so it clears up but has a stong fuel smell if your driveing behind truck . Thanks
Old 03-18-2010 | 12:14 PM
waldersha's Avatar
Pretty normal. Just not warm enough to burn everything I would think. Once you've driven for a bit the engine is warmer and it clears up.
Old 03-18-2010 | 01:26 PM
BigErksG2's Avatar
Yup, just a cold engine. Is your timing stock? That could affect it too.
Old 03-18-2010 | 02:24 PM
timeing should be stock the guy i bought it from said it had new injectors wich i can tell there new buy lookin at them he said they were bigger injectors one or two is leaking where it goes into the head how do i fix that are they just threaded into the head is there a seal or o ring ?
Old 03-19-2010 | 07:53 AM
patdaly's Avatar
Check with the Mfgs. of the Injectors, some like different than stock timing......
Old 03-19-2010 | 12:17 PM
lgp9999's Avatar
Timing is definitely something to look at, but I've also found that a quart of 2 stroke oil in a full tank helps reduces this issue considerably as well.
Old 03-21-2010 | 06:11 PM
how would i fix the injector from leakin
Old 03-23-2010 | 12:48 PM
thewished's Avatar
I had one leaking and all I had to do was turn it a 1/4" more turn and it stopped. They strip easily so be careful.
Yes they are threaded onto the injector
Old 03-23-2010 | 02:14 PM
thanks any more input would be helpfull
Old 03-25-2010 | 10:11 PM
96_12V's Avatar
You need to contact the previous owner and get documentation on what is actually in that engine. I'm taking it you recently purchased this truck? In my case, I've owned my rig 8.5 years, and it's still 100% stock. I would want to know exactly what was put in that engine, not just "It's got bigger injectors" which is a statement that states nothing at all.
Once you have documentation in hand (including any possible warranties on the parts) you need to take this up with the supplier of the aftermarket injectors. In this case, the white smoke (you do not indicate amount) could be somewhat normal, cold diesel's of this era smoke a little white until warmed up. However the fuel smell isn't, except a little you may get backing out of a garage, etc. Something is up if that's the case.
Welcome to DTR...go a head under "User CP" and fill out your signature so we can help you more in the future. Good luck with your truck.
Old 03-25-2010 | 11:54 PM
West Coast's Avatar
How much bigger are the injectors from stock? I installed 370's in my old 94 and it would haze a lot on cold starts. And even after it warmed up I could still get haze if it was under 55 degrees.....
Mostwanted
02-08-2004 12:06 AM
xzlram
12-24-2003 05:21 PM
gyroite
06-11-2003 09:24 AM
DC
12-05-2002 09:34 PM
Quick Reply: 95 12valve
