95 12 engine
95 12 engine
im in the middle of a engine and trans swap in my 90 1st gen. is there anything different electronics wise between the 95 and 90 motors that i should know about? can the fss be controlled by a toggle switch?
The crank sensor is to control the transmission. You can connect the shutdouwn solenoid to a relay then to a hot wire of the ignition. There is no electronics that control the engine.
alltimelow1
04-06-2005 07:28 PM
Stevenc
12-28-2004 08:29 PM
