6spd in a 12v, can you do it easy?
Old 04-17-2008 | 01:28 PM
IntakeRacing's Avatar
96 dodge ram dually 12v. he has hte 5speed right now, wants to know if you can put hte 6spd behind it. 4x4.
Old 04-17-2008 | 01:38 PM
rich's Avatar
i did in my 03 but it is easier in these trucks, flywheel and clutch is different, you need the front driveshaft and the front of the 2 piece,the transfer case rod is longer, the crossmember mount is further back. not sure about your year model transfer case tho mine worked, if you have a donor truck then its easy if not you need to make sure you have it all. if you have to buy a new clutch southbend has the whole kit for conversion as far as clutch and flywheel the tranny is 6 to 8 inches longer and about 300 lbs heavier but we did mine in 4 hrs
Old 04-18-2008 | 02:51 AM
Moparmax's Avatar
You will also need the cross member for the 6sp. Some of th e98's had them... mine does so you can mount it up. MTH
MM
Old 04-18-2008 | 11:17 AM
mr_ed's Avatar
From: Ordered to Elizabeth City NC. rather be back in north Idaho
If he's lookin to unload the 5spd gimme a holler I be lookin fer one...
Old 04-18-2008 | 03:09 PM
GAmes's Avatar
You can do it but it won't be cheap. Also be advised that 6 speed parts are getting very hard to find.
Old 04-18-2008 | 03:38 PM
Troutstrannysvc's Avatar
Don't understand why he would want too..
Unless he is looking for the split through the gears.
He isn't going to find any better gas mileage.
Also the early NV5600 came w/ small inputs, and 12.25 clutches, so if he finds one of those he can use same clutch, ect.
Old 04-18-2008 | 03:50 PM
xzaq103's Avatar
Im also wondering why.
Old 04-19-2008 | 01:42 PM
rich's Avatar
the 56 seems to hold up better under more power then the 45 i've been thru a total of 11 4500's
Old 04-20-2008 | 12:34 AM
dieselman2300's Avatar
I guess thats why all the big pullers go for th NV4500 instead of the NV5600.
Everyone thinks the NV5600 is a stronger tranny, but thats not the case.
If youve been through 11 NV4500, you need to either buy a NEW one or find a different rebuilder.
Old 04-21-2008 | 09:26 AM
rich's Avatar
its been new and rebuild and new from dodge, i work my trucks and they pull 20k 500 miles not for 400 ft
Old 04-21-2008 | 03:09 PM
gmctd's Avatar
NV4500's are popular for pulling\racing because they're easily repairable, onsite - NV5600 hard parts are scarce, takes a large wheelbarrow full of jigs and fixtures to get it apart, do it right - NV4500's are considered junk in some circles because they lose 5th o\d at the drop of a hat - NV5600's are good for towing, with perfect gearsplit - simple fix from GM and a new yoke could cure the 5spd Dodge o\d problem - still, NV5600 is best for towing
Old 04-21-2008 | 09:44 PM
GAmes's Avatar
You can replace three 4500s for the cost of the conversion, and two for the price of one 5600 rebuild, and yes, they break too.
Old 04-22-2008 | 06:54 PM
Boy I thought I was the only one that liked the NV4500.
Old 04-22-2008 | 07:09 PM
GAmes's Avatar
Not so fast. I'd love to have a gear between 3rd and 4th, I tow heavy too. Plus the 5600 is a heavier duty transmission, no doubt about that. Two problems. When 5600s could be found the conversion cost for a 2WD was around $4000, now it is probably closer to 6 grand. Then there is the problem of the speedo gear, nowhere in a 5600 for it. 4WD has their gear in the transfer case, so that is a non-problem for them.
I'll just keep replacing mine every 100k or so, I can live with it. **** sure better than an automatic.
Old 04-23-2008 | 10:45 AM
renopker's Avatar
I keep posten go with G56
Quick Reply: 6spd in a 12v, can you do it easy?
