5v TPS Signal Wire
5v TPS Signal Wire
I am receiving 5 volts on the TPS signal wire. I cut the wire near the PCM to and confirmed that it is coming from the PCM. I just replaced the PCM with remaned one from AutoComputerExchange.com and have the exact same problem. I tried replacing the brake switch and it made no difference. Are there any other sensors that would cause the PCM to send 5 volts out on the signal wire? I have been at this for a couple of weeks now and I am losing my mind...
Ok, I happen to have a 96 FSM, so here goes.
I will attach this info as well.
Your 5V supply goes from pin A17 on the PCM to 1 on the TPS and should be a white wire
Your Signal wire ( the one you say has 5V all the time ) Goes from Pin A23 on the PCM to 2 on the TPS and should be a Dark Blue wire.
Your 5V ground comes form pin A4 on the PCM and goes to 3 on the TPS and should be a Blue/Light Brown wire.
Sound about right?
If so then the only possible source of the constant +5V on the signal is from the PCM internally.
That would be very unusual indeed.
Sound about right?
You are a little off on the wire colors, the colors you gave are the tracer colors. But other than that everything else sounds and looks right. I have tried using my FSM as well, but haven't be finding it of much help in this particular issue. Does any one know if it is possible to have a sensor go bad causing it start sending voltage down the wrong wire, causing it to show up on my signal wire for the tps?
I don't believe that it has California emission standards, I also don't see an EGR tube. Where are they normally located? I called Computer Auto Exchange yesterday and asked them to send me another computer, should be here in the next day or so.
I was wondering if a sensor malfunctioning could cause this? Maybe it is sending voltage backwards through the circuit? I know its a shot in the dark but I am getting desperate here. What is every ones opinion on this theory?
tweeder_51
04-23-2007 01:38 PM
F. Flack
08-30-2005 04:59 PM
TPilaske
16
11-22-2002 08:15 PM
