5th gear nut part number
What is the latest 5th gear nut part number that a dealer or anybody else will recognize? The last one I put in lasted a 1.5 years and was the one with the split nut and clamp screw, part number 5013887-AA. I staked it 8 time around the lip and used red Loctite. I've heard of one that has a set screw. Are they better?
I pull a 12.1K 5er and have a #11 plate slid full forward. I may be upgrading to a CTD 600 and don't want to go with the fully splined shaft.
I don't remember how far the splines went through the gear, but what if I had the gear surfaced ground so the nut/washer seated against the spline instead of the gear? Would that work?
I have used both and had the split one fall off twice and the lock screw never failed I think you can get it from Zumbrota the # is 800 658 2537 Real nice people be sure you ask for the one with the set screws they have both I think... Good luck
getstucksome
07-30-2010 10:10 PM
wadecool
11-13-2006 12:37 AM
