5th gear gone!
Old 04-04-2007 | 09:46 AM
jester0401's Avatar
5th gear gone!
Hi all,
My father was driving the truck and lost 5th gear on sunday. I am not sure what to do to fix this, the cheapest way. He has been using it to move stuff to a new home in placerville,Ca and I am at school tell friday so he is stuck with out 5th. So what should I do or can I do to fix this?
Is there any one local to the area with the tools or knowledge, that could helpout a fellow member?
Thanks alot
Jesse
Old 04-04-2007 | 10:34 AM
Box5's Avatar
https://www.dieseltruckresource.com/...d.php?t=144495
Old 04-04-2007 | 10:37 AM
Valv's Avatar
Do a search for this problem and you'll get more results than you can read.
Old 04-04-2007 | 12:42 PM
jester0401's Avatar
Thanks for the replys but I dont really want to welded the nut on so that I have to get a new shaft later. I have been searching but I dont have to the tools. or the specifics on what to do. I guess I will keep searching
Old 04-04-2007 | 12:50 PM
Box5's Avatar
the only real fix IS getting the updated mainshaft, so it's a good temporary solution to weld the nut on, or get the upgraded nut.
Old 04-04-2007 | 12:59 PM
jester0401's Avatar
Thanks Box so I guess I am going to take things apart and then weld the nut on like you did! did you use any speacial tools to get thing on or off?
Old 04-04-2007 | 01:03 PM
Box5's Avatar
I had the trans in my garage, but since u have 4x4 like me, all u have to do is take the rear housing bolts off with a 12 point 10mm socket or wrench. and tap the housing off, it has 2 dowels pins that hold it in place alittle. Then u can look at my pictures and it's right there to clean up and weld, or replace with the new nut, but welding it seems to be a great solution until u want to rebuild with the new fully splined mainshaft (quad4x4 has the mainshaft and 5th gear for around $280 i think)
Old 04-05-2007 | 08:24 PM
NMCTD's Avatar
Here's a good artical about the 5th gear problems check it out http://www.quad4x4.com/NV4500%205th%...0Solutions.htm
Old 04-06-2007 | 09:38 AM
jester0401's Avatar
My plan is to try to take the tranny out or leave it in the truck and see whats going on and then decide what actions to take. I will keep updating
Thanks
-Jesse
Old 04-20-2007 | 10:00 AM
jester0401's Avatar
update
Hi all,
I decide to go with the new main shaft from quad4x4, the gold package. The staff was very helpful on the phone at quad4x4 in deciding what package to order. I am going to take out the tranny and then take it to my friend’s hydraulics shop and work on it there. I could take pictures and then post them if any one is interested. Any tips that would help would be appreciated also?
Thanks again
Jesse
Old 04-20-2007 | 10:52 AM
Box5's Avatar
sounds great.. What special tools do u need to tear apart the internals? I remember somthing about buying or renting them from the dealer, to buy I think they were like $100 or so?
Old 04-20-2007 | 01:15 PM
runamuk's Avatar
Jester 0401, are you going to do this in Placerville?
Rick
Old 04-21-2007 | 03:54 PM
jester0401's Avatar
Runamuk,
I am going to take it apart in Santa Cruz and then take the tranny to my friend’s hydraulics shop in San Jose and finish the transmissions guts there. I have just moved to Placerville and don’t have all of my tools set up or a place to work, this why I am doing it in Santa Cruz.
Box5,
As far as I know I have an 8in punch, the tool to lock the 5th gear nut on and a special tool to install the new torque king designed nut.
Thanks,
Jesse
Old 04-22-2007 | 06:14 AM
Tree DR's Avatar
You don't weld the nut to the shaft. Put two nuts on the shaft and then weld the nuts together.
LemonDodge
09-07-2019 03:51 PM
cbrahs
11-01-2011 11:00 AM
LemonDodge
09-16-2010 07:33 AM
wadecool
11-13-2006 12:37 AM
Dlcorrie
09-12-2004 12:06 AM
Quick Reply: 5th gear gone!
